Open Q&A
Container monitoring rules priorities management between rules
AurelienGravier
DynaMight Champion
DynaMight Champion
Hello members,
On GKE environment with a classic fullstack deployment, I want to instrument only namespaces which ends with "-pre" and "-pro" and disable all others.
I don't have information about how priorities are managed between rules on documentation.
I suppose (on top to bottom priority ?) did you think this configuration will work on my case :
Thank you in advance.
Regards Aurélien.
Observability consultant - Dynatrace Associate/Pro/Services certified
6 REPLIES 6
Mohamed_Hamdy
DynaMight Leader
DynaMight Leader
Hi @AurelienGravier ,
yes, they are executed in order
Certified Dynatrace Professional | Certified Dynatrace Services Delivery - Observability & CloudOps | Dynatrace Partner - yourcompass.ca
I've faced the same scenario and worked fine by using equal, I didn't try to use the "end with" condition but I think it should work with any other condition operator
OK I will try and confirm to you ! Thank you so much.
AurelienGravier
DynaMight Champion
DynaMight Champion
@Mohamed_Hamdy so perhaps it could be better to start on top with the rule which disable instrumentation if namespace exists and add specific rules after.
@AurelienGravier, no need to add disable Instrumentation if the namespace exists, it will disable the monitoring for all containers
Mohamed_Hamdy
DynaMight Leader
DynaMight Leader
also, you may apply "Do not monitor containers if Kubernetes namespace does not end with", to be honest, I haven't tested this condition yet, but the most important thing is to apply the rules before deploying the operator
