Dear All,
After stopping all monitored processes and even stopping the host level monitoring, I am facing the device busy message. What is an easy solution to this situation?
mv: cannot rename /opt/dynatrace/oneagent to /opt/dynatrace/oneagent-old: Device busy
Babar
Probably the best way to find out is figuring out the process that is hanging on a file in /opt/dynatrace/oneagent
I would probably check out lsof on some of the process that are running
Hello @Antonio S.
Thank you for your comments.
It is a Solaris agent, which is not a Fullstack agent, so we instrument the specified processes and monitoring of those processes already disabled.
Babar
Did you did you find any solution for this as I am facing same issue.
Tijust
Hello @Sujit
Are you talking about the Solaris agent?
Which technology you are monitoring?
Babar
