12 Sep 2025 01:41 PM
Hello
There is a requirement where the customer wants to plot the minimum and max pods allocated to workload. I have used the desired pod count metric and pod metric too and even used the aggeregation but it is not reflecting the correct value as the value of min and max is static.
Thanks in advance
12 Sep 2025 03:10 PM
Hi Prasad,
The Desired pod count metric usually reflects the number of pods Kubernetes wants to run (from the deployment/replica set), not the actual number. The min and max just give you the highest and lowest number of running pods at a certain period of time. This can be lower or higher f.e. during updating or maintenance.
What would be the customer requirement here? What question would they want answered?
KR.
Michiel
12 Sep 2025 03:34 PM
Hi Michiel
The customer has OCP where they have defined min and max pods configured for all workloads. They want to see the same in classic dashboard.
Is there a way we can capture this and display?
