21 Dec 2018
07:32 AM
30 Aug 2022
04:02 AM
Quick question about maintenance window setup in Dynatrace SaaS.
If I setup a mainteance window to not detect or alert from 5am to 9am every Saturday during server reboots of 2 specific servers and I make the scope for Host equals host1 and host2, will Dynatrace then ignore not just the hosts but also everything running on them? Hoping I don't need to scope everything that runs on the servers as well.
Yes, it works like you wrote.
Thank you!
It does not appear so. See https://answers.dynatrace.com/spaces/483/dynatrace-product-ideas/idea/221364/rfe-add-or-fix-if-its-a...
