14 May 2018
09:04 PM
17 May 2021
11:50 AM
Hello everyone!
we have a problem documented as:
Process IIS app pool namehere
Long garbage-collection time
Garbage collection is suspending process IIS app pool namehere on host hostnamehere
Root cause: ESXi Host namehere
Memory saturation
Memory is swapped in at a rate of 6.4 MB/sec
Host nameheretoo
Memory saturation
Memory is swapped in at a rate of 6.3 MB/sec
---now my cuestions: how we can fix this? what else can we do now that we have dynatrace pointing this type of trouble? our developer ask about HOW TO FIX IT? saying if this is an IIS tweaking thing?
what else can we do to help this type of problem be fixed or proactively fixed?
tyvm in advance for your concern
RKPO
14 Mar 2020 03:51 AM
@Robert P. we had the same issue, we had to work with the dev team to figure out the sweet spot for the garbage collection, how often it runs, the max load before it runs and the duration, Its alot like CPU wait time with VMware, You want to find that sweet spot where you have enough CPUs for the host but dont have too much where it is waiting for CPU to become available
