Open Q&A
Help in writing a JS code for workflow
AK
Pro
Hi Folks,
Need some help in writing a JS code for workflow.
I'm using "Issue an HTTP request to any API" call to fetch the response and I wanted to objects from this response to next "Issue an HTTP request to any API" call.
As far as I know, we cannot pass objects directly from "Issue an HTTP request to any API" call to next step/call. We have to use "Build a custom task running js Code" to store the values/objects and use for next step or API call.
The body for first API call comprises of,
    "objectId": "abscdf",
    "summary": "",
    "searchSummary": "",
    "created": 12345677,
    "modified": 78901234,
    "createdBy": "elstfsvs",
    "modifiedBy": "elstfsvs",
    "author": "[email protected]",
    "updateToken": "123456absbdsld",
    "scope": "APPLICATION-123456xyz",
    "schemaId": "builtin:rum.web.rum-javascript-updates",
    "schemaVersion": "1.1",
    "resourceContext": {
        "operations": [
            "read",
            "write",
            "delete"
        "modifications": {
            "movable": true,
            "modifiablePaths": [],
            "nonModifiablePaths": []
    "value": {
        "JavascriptVersion": "CUSTOM"
Based on JavascriptVersion, I wanted to pass application ID to next request which is actually POST api call.
I tried to write the below JS code, I'm able to get whole response body but how do I get those objects and pass it on to next API call.
// optional import of sdk modules
import { execution } from '@dynatrace-sdk/automation-utils';
  export default async function({execution_id}) {
  const ex = await execution(execution_id);
  const data = await ex.result('check_rum_version');
  console.log(data);
Can someone help here.
AK
AK
Pro
Can somebody please share some thoughts on this.
AK
Pro
I'm able to get this with below code.
  const Scope = data[0].json.scope;
  return Scope;
  console.log(Scope);
AK
