Open Q&A
Host anomaly detection settings are not applicable for PaaS or standalone deployments
sujit_k_singh
Leader
Under the host monitoring, i am seeing message "Host anomaly detection settings are not applicable for PaaS/standalone deployments." what does that means.
5 REPLIES 5
Mizső
Hi @sujit_k_singh,
I have only managed PaaS implemantations (some Solaris systems). I thnik at PaaS implemantation only the process is instrumented, there is not any host level metric collection. So I thnik that is why you can not change the host level anomaly detection rules eg. host level CPU saturation and so on...
I hope it helps.
Best regards,
Mizső
Correct.
Platform as a service abstract user from the OS. Oneagent PaaS implementation is about the process not the OS
Helpful, thanks!
DT_NGINX_FORCE_UNKNOWN_VERSION_INSTRUMENTATION=1
sujit_k_singh
Leader
@Mizső and @PacoPorro  Thanks for your message... I am clear not even that make sense too.
dan_m_smith
Helper
This raises the question of JVM level Anomaly Detection.  I find it odd that these have always been defined at the Host Level and not the Process Level  So on our Kubernetes platform running BottleRocket O/S (AppOnly deployment=Paas), we have no way to control the garbage collection anomaly detection settings.  If it as defined at the Process level this would not be a problem.
Does anyone have a solution for this, other than Custom Metric Events and Process level tagging or naming.
