04 May 2018
03:34 PM
18 Oct 2022
12:19 PM
I am trying to enable Dynatrace OneAgent Monitoring for IBM WebSphere Application Server, the installations was complete using root as per requirement, the user used to run IBM WebSphere Application Server
The .profile file of the user that is used to start IBM WebSphere Application Server was amended and added with the following:
export DT_HOME=/opt/dynatrace/oneagent
export LDR_PRELOAD64=$DT_HOME/agent/lib64/liboneagentproc.so
export LDR_PRELOAD=$DT_HOME/agent/lib/liboneagentproc.so
Is there anything I am missing.
ISSUE: We even after restarting the IBM WebSphere Application Server process, we are still getting a prompt to restart the process.
Screenshot of WebSphere even after restarting the process, automated injection not working.
10 Aug 2018
01:28 PM
16 Oct 2023
03:58 PM
random_user
We got this similar issue you as https://community.dynatrace.com/spaces/482/dynatrace...
Do you solve it already?
17 Oct 2018 08:10 AM
Up, I have similar case
19 Oct 2018 06:51 AM
I have similar case. Did you resolv the issue ?
19 Oct 2018 08:12 AM
We already resolve just update OneAgent version 1.151+
11 Jan 2019 03:43 PM
I have the same case. end i heve oneagent version 1.157
