Is it possible to keep sending mail until Problem closed?
tfukuda
Contributor
Hi all,
I have a question about Problem notification.
Is it possible to set the transmission interval if possible?
Best Regards,
Tomoko Fukuda
3 REPLIES 3
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
No that's not possible. You only get updated if the problem increases in severity, e.g.: from slowdown to availability level.
In order to solve that use-case you could use our OpsGenie, VictorOps, PagerDuty integration as those incident management systems offer a repeated notification over time.
Best regards,
Wolfgang
mat_cat_adn
Advisor
Maybe with a custom alert, you can configure a time of problem during a sliding timeframe :
https://www.dynatrace.com/support/help/monitor/pr...
Mathieu
Ashok_Selvaraj
Frequent Guest
Any suggestion/workaround without multiple alerting profile to trigger an notification everyday for open incident till it is resolved.
