The message you are trying to access is permanently deleted.
12 Apr 2019 12:54 PM - last edited on 13 Dec 2021 03:02 PM by MaciejNeumann
We'd like to monitor business processes with Dynatrace Managed. Is it possible?
By a business process I mean the following steps: let's say a user logs into a portal, orders a cell phone, makes payment and logs out. I'd like to see, if this steps were successfull with some monitoring data.
12 Apr 2019 02:16 PM - last edited on 29 Aug 2023 03:42 PM by ghaydtner
Hello Andras,
With conversion goal you can set, for example the successful payment page or method as a conversion. Then you can analyze every single visit that had this conversion (so every single user action).
Regards
12 Apr 2019 10:33 PM
It depends on a clear definition of what you want to view and measure. With conversion goals, you have the "business" point of view - how many sessions have reached a particular goal. Typically it won't give you any clues if a step failed or the user just did not process to a step you expected him/her to go.
On the other side - server side monitoring will give you exact reasons why a particular request (that is not necessarily a user action) failed. That's more the operations view. With clever usage of request attributes, you can evaluate business processes "status" on the server side and see if particular steps fail or not and see the reasons.
I'd recommend to set your expectations very very clearly and determine if it is the DEM (real user monitoring) or server side. Typically you will end up of using both.
26 Apr 2019 11:27 AM - last edited on 12 Feb 2024 08:18 AM by IzabelaRokita
Basically, what I mean by business process monitoring is the feature like Business iQ provided by AppDynamics. Comparing Dynatrace with AppDynamics, can we say that Dynatrace can deliver the same monitoring in terms of this feature?
26 Apr 2019 09:15 PM
I'm not familiar with Business IQ, however by comparing the data presented on the screenshots I think Dynatrace definitely provides such features.
