07 Nov 2020
06:32 PM
06 May 2021
12:58 PM
Hi All,
I'm using Dynatrace Managed and connect to multiple vCenter via the VMWare integration. Is it possible to create a management by virtual machines? The reason behind is a signal ESXi host contains VM of multiple countries, I want group them into different management zone for dashboard and analysis.
08 Nov 2020 04:34 PM
We have used the APIs to load our VMware tags into Dynatrace. We can then use the tags to filter or create mgmt zones for dashboard filtering. That way you could tag your VMs with country info in VMware and use those.
09 Nov 2020 01:28 AM
That sounds great, Bill. Is it API from VMWare or Dynatrace? Could you tell / guide me how to do that?
Sylvian
13 Nov 2020 01:46 AM
Hi Bill,
May I have your advice please? Many thanks.
Sylvian
