22 Mar 2023
07:20 PM
23 Mar 2023
07:55 AM
Hello -
I am looking for a way to map a custom metric (being ingested from a third party data source) to a Management Zone. This will allow me to set up an alerting profile & problem notification definitions for the custom metric. I have searched the documentation but so far I am having difficulty determining how this is done.
Does anyone have advice on how to map a custom metric to a new Management Zone?
Joel B
22 Mar 2023 11:13 PM - edited 22 Mar 2023 11:15 PM
Hi @j_butzow, please find your answer in the image attached below
in the value field you can add more text to match your metric.
23 Mar 2023 12:12 PM
Thanks Daniel. I was a bit confused because nothing was showing up for me when I hit "Preview Entities", but it does work.
Cheers!
