Open Q&A
Monitoring Bandwidth Utilization for RUM and Data Transmission to Dynatrace
Vikas_g1997
Dynatrace Organizer
Dynatrace Organizer
Hi Team,
Is there a way to monitor or estimate the bandwidth utilization of Real User Monitoring (RUM)? Additionally, I would like to understand how to check the network bandwidth consumed by machines when sending data to Dynatrace.
Looking forward to your guidance.
Fin_Ubels
Dynatrace Leader
Dynatrace Leader
Hey @Vikas_g1997
There are a bunch of self monitoring metrics which you can find when searching "dsfm" in the metrics app. I couldn't spot anything for RUM bandwidth but there are beacon counts so if you get an average beacon size you can roughly estimate it.
As for bandwidth consumed by agents, again couldn't spot anything specific but there are traffic metrics for Activegates. So assuming your agents are communicating through Activegates you could use those metrics to better understand traffic.
Patrick_H
Dynatrace Leader
Dynatrace Leader
Data usage heavily depends on how the app is instrumented, but there is a guidance on how to get an estimation:
https://docs.dynatrace.com/docs/shortlink/cost-and-traffic-control-mobile#network-bandwidth-consumpt...
iOS help: https://www.dynatrace.com/support/help/shortlink/ios-hub
