Open Q&A
Monitoring adaptive load reduction
henk_stobbe
DynaMight Leader
DynaMight Leader
From the documentation I understad that you are warned if ALR kicks in:
    You are informed about the reduction of processed data by
  • An alert message in the Dynatrace web UI: Server [amount] activated adaptive load reduction
  • A message in the distributed trace list: [amount] more like this
 Does this simply mean that whan a service exceeds 1000 request/s this happens. Or in other words can you monitor this number with a threshold of 900 if you want to prevent this from happening?
KR Henk
AntonioSousa
"Adaptive load reduction" and "Adaptive traffic management" are sometimes treated equally, despite being a little bit different. You quoted the following page, which also mixes these two concepts:
https://www.dynatrace.com/support/help/observe-and-explore/purepath-distributed-traces/adaptive-traf...
If we're talking about a Managed environment, ALR is more adequate. There have been discussions here in the past, and I would suggest the following two threads:
If we're talking SaaS, then this thread might also be interesting:
https://community.dynatrace.com/t5/Open-Q-A/The-Problems-with-Adaptive-Traffic-Management-Version-2/...
Additionally, if talking SaaS, I believe Grail will impact the way traces are stored. but this has not been anounced, to my knowledge.
Antonio Sousa
Took a long time to aswer (its a little busy)
But thank you,
Henk
