13 Mar 2019 08:21 AM - last edited on 14 Jun 2021 07:54 AM by Karolina_Linda
Need to monitor SSL certificate expiry and generate alert for the same.
13 Mar 2019 08:57 AM - last edited on 16 Oct 2023 03:47 PM by random_user
Can you please create a product idea for this use case with some details:
https://community.dynatrace.com/spaces/483/view.html
For example: Could we create a synthetic monitor and check for the certificate? Do you want to get the alert X-days before it expires or just if it is expired?
At the moment Dynatrace can't do that.
13 Mar 2019 10:35 AM
Hi Alexander,
Could you please elaborate more on synthetic monitor. How can we create synthetic monitor for SSL certificate expiry check ?
Any example would be appreciated.
And yes we want an alert to be triggered atleast 2 days before expiry.
18 Sep 2019 12:35 PM
@Alexander S. :Could you please share your inputs on my above query. For creating a synthetic monitor we will need some URL to add, it would be good if you give some example so that i can replicate the same in my environment. Thanks
looping @Juliano C. who supports us in our program.
Vikram
19 Sep 2019 10:41 AM - last edited on 16 Oct 2023 03:38 PM by random_user
Just to keep all the info within the same post, I'd like to add the Product Idea raised by Vikram regarding this topic:
https://community.dynatrace.com/content/idea/219003/view.html
31 Mar 2021 03:05 AM
Hi All,
You can now check SSL certificate expiry directly from Dynatrace synthetic HTTP monitors.
As of cluster version 1.2.12
25 Aug 2022 03:55 PM
This works really well, but it would be good to be able to schedule the frequency for more than once an hour. Once a day or even once a week would be frequent enough to check for the certificate expiration. Can we get a longer time for these tests, please.
25 Aug 2022 04:45 PM - edited 25 Aug 2022 04:47 PM
@Bill_Demsky totally agree with your request !
Till this request will be full fill you can try utilize Maintenance Window to suppress the running of synthetic checks.
Tried that and its look its working OK
Another way to run it every now and then will be by using API: Synthetic - On-demand monitor executions
HTH
Yos
31 Mar 2021 09:40 AM
You can use the SSL cert check plugin my colleague @r_weber wrote.
04 Apr 2022 10:29 PM
I would be nice if this was built into the full stack monitoring.
