Open Q&A
Oracle DB Leak Connection
gauresh_shinde
Contributor
Hi All,
We need to find oracle DB leak connection associate with which request/service?
Gauresh
Mizső
Hi @gauresh_shinde ,
I have only experience with Weblogic + Oracle, I can not define which request / service associated with the leaked connection. I can define only the affected data source. It is provided by the Weblogic connection pool monitoring feature. There are connection pool monitoring features for the other technologies also, but I do not know those possibilities.
Best regards,
Mizső
AntonioSousa
@gauresh_shinde,
This blog post has some details on how it works:
https://www.dynatrace.com/news/blog/simplify-troubleshooting-with-ai-powered-insights-into-connectio...
Beware that you have to have JMX configured in your Application Server. It really doesn't depend on the database being used. You can then configure one of them for your use-case:
Antonio Sousa
