Open Q&A
Prepare for Dynatrace Associate Certification? Mock Exam Guide
hila
Visitor
Summary: The Dynatrace Associate Certification validates foundational knowledge of observability and platform features. This thread provides mock exam alternatives and tips to help you prepare effectively and pass with confidence.
Hi all,
I'm planning to take the Dynatrace Associate certification exam soon. I feel that it would be better if I took more mock exams before taking the real one. I took a sample of the test from the preparation page, but I want to ensure I'm ready (100%). Is there any other resource where I can find more exams and example questions?
I'm the one who learns via questions 😊.
Thank you!
14 REPLIES 14
AntonioSousa
@hila
You might want to read what has been said in the following thread:
https://community.dynatrace.com/t5/Dynatrace-tips/Dynatrace-associate-exam-preparation/m-p/112925
Antonio Sousa
Thank for the reply. It is a good topic to review. In this case I assume there is no more practice exam in any where.
There is only one practice exam but after some of the sections in Dynatrace University courses, you can find short quizzes in an identical style. They have different questions than the practice exam and usually are a little bit harder, which makes them a little bit closer to the real test.
If you have any questions about the Community, you can contact me at [email protected]
I tried to take most of them but I did not know they are close to the real exam. I'll put more attention on it. Thank you!
Did they remove the short quiz  after every video? I don't see it.
jc__
Frequent Guest
I think so. They just disappeared.
Hi MaciejNeumann,
Do you know why the end-of-module quizzes were removed from Dynatrace University? We would like to have the questions back, if possible.
I think answer to more practice with exam questions - practice Exam
The questions of exam will be easy for you if you have hands on experience.
Romanenkov Alex
DT_NGINX_FORCE_UNKNOWN_VERSION_INSTRUMENTATION=1
The Practice exam(
Taste of the Test:
https://university.dynatrace.com/certification/21181/exam/21274
) seems to have disappeared after new format was introduced.. Is anyone still above to see the practice exam IN DTU?
Nishal
Newcomer
Hi Hila,
Thats good, Do you have any dumps for this test.
My Exam is on march - 9th -2023. If you have any dumps please share the dumps for ([email protected])
Nishal.
Hi, NIshal.
How was your exam experience? Can you share with me?
Exam dumps don't allow you to gain knowledge.
Exam is online proctored, there are huge pool of questions. The risks are too high, you will be easily identified.
Knowledge is power but knowledge without action can be useless. What a goal to try to get cert without "knowledge" and "actions"...
Kenny_Gillette
Dynatrace Leader
Dynatrace Leader
Definitely follow other thread as said above.
Knowledge Areas
1.               Capabilities & Monitoring (23%)
    1. Application Baselining
      1. https://www.dynatrace.com/support/help/shortlink/automated-baselining
    2. Log file gathering
      1. https://www.dynatrace.com/support/help/shortlink/log-monitoring-compare
    3. Options and metrics available to configure database and network monitoring
      1. https://www.dynatrace.com/support/help/shortlink/database-detection
      2. https://www.dynatrace.com/support/help/shortlink/network-hub
    4. How Process groups and services are detected and presented
      1. https://www.dynatrace.com/support/help/shortlink/process-groups
      2. https://www.dynatrace.com/support/help/shortlink/custom-services
      3. Services run off of Processes and are where the requests occur
2.               Components & Architecture (9%)
    1. Activegates
      1. https://www.dynatrace.com/support/help/shortlink/activegate-hub
    2. 3rd party integrations
      1. https://www.dynatrace.com/support/help/shortlink/integrations-hub
    3. User roles & groups for Managed
      1. https://www.dynatrace.com/support/help/shortlink/managed-user-groups
    4. How network overhead is affected
      1. https://www.dynatrace.com/support/help/shortlink/network-hub
3.               Digital Experience Management (19%)
    1. Define RUM and implementation
      1. https://www.dynatrace.com/support/help/shortlink/rum-injection
    2. Rules to tune the tracking of user actions and assign tags to components to simplify searches and group metrics
      1. https://www.dynatrace.com/support/help/shortlink/user-session-properties
      2. https://www.dynatrace.com/support/help/shortlink/user-tagging
    3. Describe data and metrics obtained through RUM
      1. https://www.dynatrace.com/support/help/shortlink/application-analysis
    4. Configure Synthetic monitors to test availability
      1. https://www.dynatrace.com/support/help/shortlink/synthetic-hub
      2. https://www.dynatrace.com/support/help/shortlink/http-monitor
      3. https://www.dynatrace.com/support/help/shortlink/browser-monitor
4.               Install & Configure (20%)
    1. Options to customize naming and recognition of services and other entities
      1. https://www.dynatrace.com/support/help/shortlink/custom-service-names
      2. https://www.dynatrace.com/support/help/shortlink/service-detection
      3. https://www.dynatrace.com/support/help/shortlink/process-group-naming
      4. https://www.dynatrace.com/support/help/shortlink/process-groups
    2. Options for configuring system settings, alerts, notifications, preferences, and enabling/disabling specific technologies, features and functions
      1. https://www.dynatrace.com/support/help/shortlink/metric-events-for-alerting
      2. https://www.dynatrace.com/support/help/shortlink/problems-hub
      3. https://www.dynatrace.com/support/help/shortlink/maintenance-window
      4. https://www.dynatrace.com/support/help/shortlink/alerting-profiles
    3. Options for installing and updating OAs/AGs
      1. https://www.dynatrace.com/support/help/shortlink/oneagent-update
      2. https://www.dynatrace.com/support/help/shortlink/oneagent-hub#installation-and-operation
      3. https://www.dynatrace.com/support/help/shortlink/update-activegate
      4. https://www.dynatrace.com/support/help/shortlink/activegate-hub#installation
5.               Problems & Resolution (13%)
    1. Discover, describe and tune anomaly detection sensitivity, override thresholds, create threshold alerts, disable alerting for certain applications, hosts, DB services, or for other tiers
      1. https://www.dynatrace.com/support/help/shortlink/problem-detection-sensitivity
      2. https://www.dynatrace.com/support/help/shortlink/metric-events-static-thresholds
      3. https://www.dynatrace.com/support/help/shortlink/anomaly-detection-prediction
      4. https://www.dynatrace.com/support/help/shortlink/metric-events-for-alerting
    2. Identify the parameters DT uses for frequent issue detection to determine healthy or unhealthy operations
      1. https://www.dynatrace.com/support/help/shortlink/frequent-issues
    3. How to identify Root Cause
      1. https://www.dynatrace.com/support/help/shortlink/root-cause-analysis
    4. Problem evolution player, Smartscape, log monitoring and root-cause analysis for problem resolution
      1. https://www.dynatrace.com/support/help/shortlink/root-cause-analysis#visual-resolution-path
      2. https://www.dynatrace.com/support/help/shortlink/smartscape-topology-hub
      3. https://www.dynatrace.com/support/help/shortlink/log-monitoring-hub
6.               Reporting & Analysis (16%)
    1. Charts and identifying data presented
      1. https://www.dynatrace.com/support/help/shortlink/explorer
    2. Identify the availability and retention of monitoring data
      1. https://www.dynatrace.com/support/help/shortlink/data-retention
    3. Options available for creating Dashboards and adding tiles
      1. https://www.dynatrace.com/support/help/shortlink/dashboards-hub
Love this. Very awesome!
