03 Aug 2026
10:19 AM
03 Aug 2026
12:44 PM
Dear Support Team ,
We would like to know if there is any supported way in Dynatrace to send notifications using Soap Web "Custom Integration"
could you pls confirm if Soap Web Integration is supported for sending Dynatrace problem / Alert notification and if there is any recommended configuration or give me the best practices ?
Mahmoud.
27 Aug 2026 06:18 AM
No, not natively. Dynatrace's Custom Integration for problem notifications only speaks REST/JSON webhooks, you can configure a webhook URL, headers, and a JSON payload template. There's no SOAP/XML option in that config screen.
Sujit
27 Aug 2026 11:51 AM
