24 Nov 2021
03:10 AM
25 Nov 2021
02:31 AM
Hi guys,
Struggle here with this new extension and need your help ....
Succeeded to set it to work and ask to fetch 12 metrics but only 6 are pulled to dynatrace.
In log (/var/lib/dynatrace/remotepluginmodule/log/extensions/datasources/dynatracesourcesnmp.log)
All the missing metrics shown with
[error] [INVALID_CONFIG_ERROR] No value reported for: metricConfig=snmp.generic.kiteworks.laLoad.3, host=XX.XX.XX.XX, oid=.1.3.6.1.4.1.2021.10.1.3.3 [status code=32]
When check with snmpget -v2c this oid return information.
What can be the issue here that prevent the fetch of the data from those oid's?
Is there a way to increase the debug level to see more information here?
In the log there are other errors that I would also be happy for your input on them and if there is any thing to do with them.
[error] [EEC_CONNECTION_ERROR] SendMintMetrics: [HTTP Status Code = 400 - Bad Request (http://127.0.0.1:14599/mint/302052773931896646)] EEC REST API call failed [status code=30]
[error] [EEC_CONNECTION_ERROR] HTTP error, dropping MINT packet (6 lines, 824 bytes): [HTTP Status Code = 400 - Bad Request (http://127.0.0.1:14599/mint/302052773931896646)] EEC REST API call failed [status code=30]
[error] [UNKNOWN_ERROR] Failed to enrich dimensions. Host: XX.XX.XX.XX: lookup YY.YY.YY.YY.in-addr.arpa. on ZZ.ZZ.ZZ.Z:53: no such host
Thanks in advance
Yos
After consulting with support over this found the follows problems:
After setting the EEC and alter extension.yaml every thing work as a charm
HTH
Yos
Have you had much luck with the Hub 2.0 SNMP development? I'm getting pretty deep into it right now with Schneider power management device monitoring and Zinwave device monitoring.
Hopeing maybe we can get a community discussion going on how to create custom SNMP extensions.
Primarily I'm wondering if you had any luck with String OIDs. Your message above concerns me because we were really looking forward to monitoring OIDs that provide the last status, then converting those values into a code that DT could store.
Hi @ct_27
Here is quote from support regarding string OIDs
HTH
Yos
