08 Feb 2024
03:33 PM
07 Mar 2024
08:39 AM
Michal_Gebacki
Hi guys,
Managed customer is trying to use problem notification thru webhook in order to start processes on their environment.
How ever, the end point of the webhook requires a Kerberos / Spengo authentication.
Is there and possibility from dynatrace prospective to support this kind of authentication when pushing notifications?
Thanks in advance for your feedbacks
All the best and stay safe
Yos
25 Mar 2024 08:29 PM
Hi there, I believe you can work with Kerberos adding an Authorization header with a previously generated Kerberos token and attaching that to the request header.
Dynatrace lets you add custom Headers in the webhook configuration.
JD.
