Open Q&A
Smartscape topology with host level information for incoming and outgoing connections
Can we visualize hosts that are making incoming and outgoing connections with a specific host using smartscape topology?
Srikanth S
marina_pollehn
DynaMight Champion
DynaMight Champion
You can indeed "limit" the Smartscape to only a specific host with its incoming and outgoing connections to other hosts. Select your specific host in the host overview and then click the three dots [...] in the top right corner. Then go to Smartscape view. Now every host related to the one you selected is shown in blue. So it's highlighted but other hosts are still shown in the background.
I always also hide unconnected hosts and inactive hosts for a better overview.
PacoPorro
Dynatrace Guru
Dynatrace Guru
https://docs.dynatrace.com/docs/shortlink/smartscape#hosts
As you can see in the picture there are in/out arrows connecting with other hosts
