Hi all.
Is it possible to know details in the o.s. client? such as RAM, cores...
Thanks and best regards!!
JAR
@JAR it is! In terms of User Sessions you can see the following data (When applicable)
Most, If not all of these metrics can be used in the USQL
Hello JAR.
I am not sure about possibility to send CPU\ RUM \ Cores by JS.
This is example for using - navigator.hardwareConcurrency - amount of CPU core
Maybe It can help you.
For some Customers we have used dtrum API to send to Dynatrace additional information like specific client information.
Romanenkov Alex
