07 Jun 2018 01:32 PM - last edited on 24 Aug 2023 08:51 AM by fstekelenburg
I am looking to setup monitors
for Datastage, Teradata or Auto-sys tool. is that possible
with dynatrace?
13 Aug 2018 09:12 PM
Same question Can we monitor Datastage 11.5 using dynatrace managed ? if yes can any one help me in letting me know the process.
16 Dec 2018 03:03 PM - last edited on 24 Aug 2023 08:50 AM by fstekelenburg
Hi, Can we install Dynatrace agent on Teradata and monitor it? Please help
21 Jun 2020 01:58 PM - last edited on 28 Mar 2023 07:37 PM by Ana_Kuzmenchuk
same here, using Datastage - can it be monitored on Dynatrace?
Datastage person says that OSH process on linux is the "workers". from Dynatrace prespective we see it as "other".
any chance anyone had done it before and has a clue what to do?
21 Jun 2020 03:31 PM
It’s always worth a shot to see if oneAgent will monitor the app. You can also always go with the agent less solution. Also if Dynatrace doesn’t pick up the process as you intended, you can always define one manually in the UI.
21 Jun 2020 05:54 PM
Hi @Chad T.
Thanks for your input !!!
Those ETL platforms are usually running step by step operations and customer would like to check if there is a way to monitor the steps, so as you said we gave it a try and its look like that the steps are run by process that dynatrace mark as "other" so the question is if someone check what is behind the "other" in order to say we can not monitor server side of IBM DataStage . For your agent less suggestion, this is not the case here as there is no UI that need to be monitor only server side.
Yos
08 Jun 2021 08:06 PM
Did you find a solution for this using Dynatrace? We have a rather large DataStage implementation and having a solution would be very beneficial.
23 Aug 2023 08:21 AM
Add me to the list. Large customer with one application infra build around IBM® InfoSphere® DataStage.
The OSH program is partly also a black box to them.
24 Aug 2023 09:01 AM - last edited on 06 Mar 2024 10:32 AM by IzabelaRokita
See also Re: IBM Information Server & Eclipse - Dynatrace Community
Regarding IBM I think the focus is on two close related products, IBM InfoSphere Information Server as well as IBM InfoSphere DataStage.
