@Chakravarthula P. CPU usage is the total amount of CPU used on the server selected. CPU System is the amount of CPU that the Operating System is using. You will find that Linux Devices have more in the legend then the windows devices:
If you add everything up under Idle, the percentage should equal the usage metric.
image didnt attach correctly
