Dynatrace Problem API Does not provide meta-data
leonerdo037
Newcomer
We are using Dynatrace Managed and we use the API to fetch problem data. We are using the problem API to fetch some meta-data about the issue but we are unable to get full information on it. For example: When we hit the Problem API against a Low Disk Space problem; the disk on which the issue persists is not available amongst the response. Is this normal?
wolfgang_beer
Dynatrace Champion
Dynatrace Champion
Yes unfortunately not all of the meta-info is exposed through the API so far. I have that on my roadmap and this will be improved within the next year.
