11 Aug 2022 10:44 AM
Hello Community
We are facing a very big issue on Mobile application (On React Native).
Some of user sessions are not detected by Dynatrace.
When we captured traffic on Fiddler and the F5, the transactions from those users are not containing the beacon or the Dynatrace tags.
So, we are suspecting that the SDK is not well initialized.
If there any one faced this issue before?
Thanks for your help.
11 Aug 2022 12:25 PM
There's not much info to understand what could be happening. I'd suggest to contact our support with log files, config file and other data that might be helpful.
14 Aug 2022 07:54 AM
Hi @thomas_billi
Thanks for your replay.
Im working with the support in parallele.
Short Update:
After removing the app from the deveice and reinstall it, the traffic is now detected.
16 Aug 2022 07:18 AM
Can you please confirm which version of react native you are using? Is there any debug logs being captured in your debug app?
