Mobile Application On React Native (auto Instrumentation Problem)
Malaik
Leader
Hello Community
We are facing a very big issue on Mobile application (On React Native).
Some of user sessions are not detected by Dynatrace.
When we captured traffic on Fiddler and the F5, the transactions from those users are not containing the beacon or the Dynatrace tags.
So, we are suspecting that the SDK is not well initialized.
If there any one faced this issue before?
Thanks for your help.
Sharing Knowledge
3 REPLIES 3
thomas_billi
Dynatrace Pro
Dynatrace Pro
There's not much info to understand what could be happening. I'd suggest to contact our support with log files, config file and other data that might be helpful.
Hi @thomas_billi
Thanks for your replay.
Im working with the support in parallele.
Short Update:
After removing the app from the deveice and reinstall it, the traffic is now detected.
Sharing Knowledge
Can you please confirm which version of react native you are using? Is there any debug logs being captured in your debug app?
KG
