07 Apr 2023
10:32 AM
23 Jan 2024
08:41 AM
ghaydtner
We have a requirement to monitor application login and homepage availability 24*7 but not with synthetic monitoring.
Could you please provide us with the available options?
07 Apr 2023 04:06 PM
Why are you not able to use Synthetic monitoring? Can you use regular RUM? You could potentially mark some key requests on the backend, and key user actions on the front end. Still curious why you can't use synthetic monitoring.
Regards
17 May 2023 12:42 PM
Harmera12 do you still need help with your case?
Or have you already found a solution? If yes, feel free to share. Other Community members would be happy to know the answer.
23 May 2023 04:46 PM
I have a similar situation in which we can't use synthetics due to security and privacy concerns.
We do have these apps configured and are collection 100% user sessions on them.
I'm wondering what metrics we can use to infer that there "could" be an availability issues.
17 May 2023 01:23 PM
Within Dynatrace, Availability is directly linked to synthetics. Keeping cost in mind, you could set up a basic HTTP monitor that test your application every 30 mins from 1 location at an estimated cost of $10 per year. Granted that cost is dependent on your current license/contract.
17 May 2023 02:30 PM
You can use RUM but it only works if you application have users 24x7 also.
Monitoring availability 24x7 is a perfect example to use Synthetics monitoring.
Best regards
27 Jun 2024 01:42 PM
How can use RUM (metrics) to get the availibilty
