Browser click-path is failing due to current date on homepage
AK
Pro
Hi Folks,
We have browser click-path monitor, there is date field once homepage is launched.
This date field takes the current date which system has.
At the time of recording the date was different and during the autorun it obviously gonna take current date and this is causing the click-path to fail.
How can we skip this date field check. How dynatrace is comparing the pages and element in it?
AK
4 REPLIES 4
cv_dewr
Helper
hi AK,
the date being different on the page shouldn't make a difference to the validity of the check, unless the recorded script was configured to explicitly check it.
Take a look at the config of the browser monitor and ensure it's not doing a validation check for the date as it was.  If it is remove that validation check, or better yet, change it so it checks for something on the page that doesn't change unless the page is broken.
eduard_van_der1
Dynatrace Helper
Dynatrace Helper
When the monitor fails, it will show in screenshots what the difference was - what was the exact error that was reported?
@eduard_van_der1, it shows
1304 - Wait for page complete timeout
AK
Hi, in that case you might want to review the amount of time waited - there might be something hanging in the app that causes the browser timing / synthetic monitor to keep waiting.Screenshot 2023-11-15 at 14.39.06.png
