22 Aug 2023 08:29 AM - edited 23 Aug 2023 06:43 AM
Hello everyone!
I have a question. I need to monitor a webpage, which is only available using certificate authetication.
Can you please tell me, how can I configure it?
With aprreciation, Kirill Sverchkov.
22 Aug 2023 08:33 AM
Hi @ksverchkov
Check client certificate authentication for endpoints
HTH
Yos
22 Aug 2023 08:37 AM
Hi @Yosi_Neuman.
It is an http monitor, but I need to monitor webpage using browser, because it is dynamically rendered by js.
22 Aug 2023 08:43 AM
Hi @ksverchkov
For browser click path check HTTP authentication
Hope this will help you better
Yos
22 Aug 2023 08:48 AM
@Yosi_Neuman , it is better, but it is still not ssl authentication. HTTP authentication is another thing.
22 Aug 2023 08:56 AM - edited 22 Aug 2023 09:00 AM
HI @ksverchkov
With HTTP authentication you pick an authentication from the Credential vault for synthetic monitors
One kind of authentication that you can store with in this vault is certificate
Hope now you got full answer to your question
Yos
22 Aug 2023 09:27 AM - edited 22 Aug 2023 10:01 AM
@Yosi_Neuman , I also hope, that now I have got a full answer for my question, but I am trying to do it in on-line mode.
So, I created a credential:
After it I go and try to create a synthetic request with this credential:
And there is no ssl authentication.
Can you show an example?
22 Aug 2023 11:48 AM
Is this what you're looking for? https://www.dynatrace.com/support/help/whats-new/release-notes/saas/sprint-272#certificate-authentic...
22 Aug 2023 12:05 PM - edited 22 Aug 2023 12:38 PM
Yes, it it, what I was looking for.
So before the version 1.272 this feature was not available?
Maybe some there was any workaround?
* we have version 1.262
22 Aug 2023 02:13 PM
Ah, ok. We previously had a more manual version which could be used on Private Synthetic ActiveGates. Unfortunately, it's not supported but I can confirm that other customers are using the same set up successfully. If you open a chat, one of my colleagues will be able to provide the instructions specific to your OS.
22 Aug 2023 07:36 PM
What chat? I can not find it.
22 Aug 2023 07:43 PM - edited 22 Aug 2023 07:47 PM
@HannahM probably referring to a chat with Dynatrace One.
Alternatively, if it wasn't available then you can see how to turn it on:
https://www.dynatrace.com/support/help/get-started/dynatrace-ui/troubleshoot-access/chat-issues
