Content validation question
Mizső
Hi Folks,
What is the problem with my content validation rule? What is worng with my configuration?
If I leave blank the last confirguration I always receive: Placeholder values were not defined
If I fill out with the default {windows[0]} the last configuration I always receive: The specified target window "{window[0]}" is not found
Thanks in advance.
Best regards,
Mizső
3 REPLIES 3
AntonPineiro
Is that a label as plain text that appear in the webpage?
If yes, I would remove "{" and "}" in specific text field and I will remove "{window[0]}, just blank.
Best regards
Hi @AntonPineiro,
I have not understand correctly the explanation about the brakets...
It works fine based on your guidance.
Thanks very much.
Best regards,
Mizső
You are welcome.
I wanted to say removing placeholders, only specific text. It means "my text" instead of "{my text}".
Best regards
