18 Apr 2023 12:27 AM
Hello all,
Currently I have ActiveGate for remote technologies with extensions.
Refer to this documentation -> https://www.dynatrace.com/support/help/platform-modules/digital-experience/synthetic-monitoring/priv... , I should uninstall existing ActiveGate first before I could enable synthetic for private location function.
Does it mean that my ActiveGate will no longer able to remote technologies with extensions?
Is it possible to have 1 ActiveGate but with two function such as Private Location Synthetic Monitor and Remote Technologies with Extensions?
Thank you.
18 Apr 2023 12:48 AM
Not officially supported by Dynatrace, but it can be done (I have one working case):
27 Jun 2023 11:10 AM
Thank you for the insight.
27 Jun 2023 12:35 PM
It still works (for you)? I think I tried with recent AG and the setting had no effect.
