Dual ActiveGate Function - Synthetic Monitor and Monitor Remote Technologies with Extensions
agylpradipta
Helper
Hello all,
Currently I have ActiveGate for remote technologies with extensions.
Refer to this documentation -> https://www.dynatrace.com/support/help/platform-modules/digital-experience/synthetic-monitoring/priv... , I should uninstall existing ActiveGate first before I could enable synthetic for private location function.
Does it mean that my ActiveGate will no longer able to remote technologies with extensions?
Is it possible to have 1 ActiveGate but with two function such as Private Location Synthetic Monitor and Remote Technologies with Extensions?
Thank you.
4 REPLIES 4
AntonioSousa
Not officially supported by Dynatrace, but it can be done (I have one working case):
https://community.dynatrace.com/t5/Synthetic-Monitoring/Regular-ActiveGate-for-synthetic-monitoring/...
Antonio Sousa
Thank you for the insight.
It still works (for you)? I think I tried with recent AG and the setting had no effect.
Kind regards, Frans Stekelenburg                 Certified Dynatrace Associate | measure.works, Dynatrace Partner
@fstekelenburg,
I have one still working, but it's in version 1.239...
Antonio Sousa
