17 Jun 2021 02:46 PM
I have a synthetic transaction that opens a page and, using a simple java script, reads the page for a value. This worked until about a month or so ago and then stopped. If I play it back, the only way to get it to work again is by clicking 'Cancel' on the button next to the statement "Dynatrace Synthetic Recorder started debugging this browser" and the reloading the page.
Does anyone know if there was a change to the extension that caused this to start happening? It had worked fine up until that point.
Thank you for any help.
17 Jun 2021 03:31 PM
Hi Richard
I don't have any insight myself into the construction of the recorder, but I have seen where scripts do break. Sometimes this is due to the construction of the synthetic execution, or perhaps the web page has been changed as well. Either way, the best and simplest fix is to re-record your test. This ensures that whatever changed, it is working now.
Good luck
Bobby C.
17 Jun 2021 05:17 PM
Hi Bobby,
Thanks for the response. I have tried re-recording the synthetic but haven't had much luck.
Some odd behavior:
When I start my recording it automatically opens a second tab.
I am seeing errors in the DT extension like this: Unchecked runtime.lasterror: No tab with given ID xx
The context is backgroud html. I'm not really a developer so I'm working on a learning curve.
18 Jun 2021 10:17 AM
Hi Richard, can you ask in chat about this and then we can investigate this behaviour. Thanks, Hannah
