08 Aug 2017 01:37 PM - last edited on 08 Dec 2021 12:23 PM by MaciejNeumann
I am exploring all the possibilities to integrate Synthetic Monitoring with Dynatrace. I have generated a token for Synthetic Integration. When I try to pass the API token within an authorization header Its giving me below error:
{"error":{"code":404,"message":"failed to resolve tenant <23936>"}}
Can some one help me how to resolve this?
08 Aug 2017 03:03 PM
Was the feature turned on for your tenant? At the moment this feature is in closed beta status and needs to be turned on for your environment. Best would be to contact your Dynatrace contact in order to get in touch with one of the product managers.
08 Aug 2017 11:35 PM
Does (will) this feature work for Managed? I noticed the UI says "Dynatrace SaaS integration".
10 Aug 2017 11:42 AM
Yes, it will also work for Managed.
12 Dec 2017 03:25 PM
Is this still in beta and needs to be turned on?
(running Dynatrace Managed version Version 1.132.87.20171117-162916)
15 Nov 2021 06:31 AM
I am getting failed to resolve tenant 10 error using Postman any idea how to resolve.
15 Nov 2021 09:27 AM
Hi Naveen,
please can you contact chat and explain what you are trying to do? They should be able to help. This feature was for integrating Classic Synthetic Monitoring with Dynatrace Synthetic. Classic Synthetic monitoring has been end of life for sometime now.
If you are trying to push third party monitor data to Dynatrace you can find further information on that API here
