Synthetic Monitoring
How to mimic double click in the Browser Monitoring?
Arunkumarbnp
Helper
How to mimic double click in the browser monitoring
4 REPLIES 4
sia_h
Dynatrace Champion
Dynatrace Champion
You must add a Synthetic event of type Javascript:
Then, use JavaScript like the example below, making sure the querySelector targets the specific HTML element you want to double click.
var event = new MouseEvent('dblclick', {
'view': window,
'bubbles': true,
'cancelable': true
document.querySelector('#CSSElement').dispatchEvent(event);
Arunkumarbnp
Helper
@sia_h
Thanks for your quick reply.
I'll check and accept your answer as solution.
HannahM
Dynatrace Guru
Dynatrace Guru
You can find this documented here: How to perform DoubleClick event on browser click path synthetic monitor.
There are lots of helpful guides here: Synthetic Troubleshooting Map
Arunkumarbnp
Helper
@HannahM
Thanks for your reply.
I'll check on it.
