How to pass token type credential vault as header in browser click-path monitor
AK
Pro
Hello Folks,
When I use it like above for HTTP monitor it worked very well but its not the case with browser click-path monitor.
Kindly suggest and help.
AK
3 REPLIES 3
DanielS
It is important to understand what is expecting the app for the use of the header. In this case I need to use a header as client_id to be accepted.
@DanielS, Thanks for response.
That is true in case of HTTP monitor but how can we achieve same for browser click-path monitor?
I'm fetching some data from Dynatrace API itself which require to pass Api-token as query parameter or as Authorization header.
AK
AK
Pro
I checked with support, this functionality is not supported.
We cannot pass the credential vault via header in browser click-path monitor
AK
