01 Sep 2024 07:35 AM
Hi All,
We want to validate SSL certificate expiry date so we can use "HTTP monitor" , this monitor can be run from 1min to 60mins frequency but we want this to run only once per day.
Please suggest how it can be done.
Guru Gogi
01 Sep 2024 08:01 AM
Hן @Gogi
IMO You can set Maintenance Window with Disable synthetic monitor execution for that
HTH
Yos
02 Sep 2024 12:55 AM
Hello @Gogi ,
For your use case, you need to run the synthetic monitor on-demand through the Dynatrace API. https://docs.dynatrace.com/docs/dynatrace-api/environment-api/synthetic-v2/synthetic-monitor-executi...
This can be done through any tool with scheduling and especially in Dynatrace Saas through Workflows.
16 Sep 2024 03:12 AM
Note that for this use case there's probably a better option with the SSL Certificate Monitor extension.
https://www.dynatrace.com/hub/detail/ssl-certificate-monitor/
