How to run synthetic monitor only once per day (SSL certificate check)
Gogi
Helper
Hi All,
We want to validate SSL certificate expiry date so we can use "HTTP monitor" , this monitor can be run from 1min to 60mins frequency but we want this to run only once per day.
Please suggest how it can be done.
Guru Gogi
3 REPLIES 3
Yosi_Neuman
Hן @Gogi
IMO You can set Maintenance Window with Disable synthetic monitor execution for that
HTH
Yos
MarcioKaue
Helper
Hello @Gogi ,
For your use case, you need to run the synthetic monitor on-demand through the Dynatrace API. https://docs.dynatrace.com/docs/dynatrace-api/environment-api/synthetic-v2/synthetic-monitor-executi...
This can be done through any tool with scheduling and especially in Dynatrace Saas through Workflows.
cv_dewr
Helper
Note that for this use case there's probably a better option with the SSL Certificate Monitor extension.
https://www.dynatrace.com/hub/detail/ssl-certificate-monitor/
