18 Jun 2025
03:55 PM
18 Dec 2025
10:56 AM
Michal_Gebacki
Hello.
I want to set maintenance windows for the synthetic monitor (HTTP or ClickPath ).
I have some monitors that I don't want running on weekends, and some that I don't want running between 18H:00 and 23H:00 (only during office hours).
This means that during this time slot, like weekends and between 18H and 23:00, those synthetic monitors need to be disabled, or if they cannot be disabled, I want to avoid any outage handling.
I was thinking about setting maintenance windows for that.
Could you please advise how to do that?
BR
18 Jun 2025 04:52 PM
If you are in Grail, I would say Synthetic for Workflows. It has more flexible schedules.
If not, I would say combination of maintenance windows + Disable synthetic monitor execution . But I think you need to create more than one to have those schedules.
Best regards
18 Jun 2025 05:26 PM
Easiest - let the synthetics run all the time and create a maintenance window for when you don't want to alert/create problems
