LDAP Synthetic ssl unknown error
SabineR
Helper
We are trying to use LDAP Synthetic extension and it fails witht the following message:
LDAP Search returned error: Failed to connect to LDAP server ldaps://xxxxxxxxx:636 - ssl: Unknown error.
The port is opened between Dynatrace ActiveGate and the LDAP server. TCP ssl port.
How can we get more detail on this error?
Is there anything we have to add on the activegate?
Many thanks in advance for your help,
Sabine
Mizső
Hi @SabineR,
Have you cheked the extension log on the ActiveGate?
Increase the log level to debug for the investigation.
Best regards,
János
