Need offline installer for Dynatrace Synthetic Recorder
rzayas28
Visitor
We have a bunch of machines behind firewalls and need an offline installer for the synthetic recorder plug in.
Thanks for the help.
gopher
Champion
Hi rzayas,
You can use 'katalon'  as an offline recorder, it's an available extension for chrome / edge / Mozilla. it has all the features and more and can export into the Dynatrace format.
your scripts will also end up looking significantly cleaner.
Enjoy
