Synthetic Monitoring
Private Synthetic Monitoring: Kubernetes Location
Amarjit
Frequent Guest
I have set up a ActiveGate in the Kubernetes cluster and it is connected to the Dynatrace cluster as per status.
I want to execute a Browser monitor script in this activegate while recording the application and playing locally i am able to successful execute the script.
But the same when i am executing via the private location running in kubernetes cluster i get the Unauthorized error.
Could you suggest if i need to perform any additional steps
HannahM
Dynatrace Guru
Dynatrace Guru
At what step is this monitor failing? If it's at the first one, then I suspect you need to add HTTP Authentication details in, or possibly the machine you are using doesn't have access allowed to the site and may need to be added to a list of allowed IPs/ machines etc.  If it's after you enter the password, then I would try a curl to the same url which includes the username and password. You can find some helpful curl commands here
Peter_Youssef
Leader
Hi @Amarjit
for authorization issues either:
  • Using an authorized user account (UN & PW ) which is actually configured within the app itself.
  • You can create authorization header to avoid such failures.
  • Another way is create a credential vault with the authorized access credentials (UN && PW) and save it in credential vaults, this issue should be resolved.
KR,
Peter
