Synthetic Monitoring
Synthetic Monitor Http Status Code 403
Gib80
Contributor
We are receiving the below (see attached) status code 403 on a synthetic monitor.  Could someone advise what this might mean as the Synthetic monitor is showing as ok?
Kind regards
HannahM
Dynatrace Guru
Dynatrace Guru
The status code 403 means Forbidden. You are likely trying to access a page that requires credentials or for your IP etc to be allowed.
The HTTP Monitor will show this as success if you have set that in the HTTP Monitor > Settings > Requests> Response Code verification section
