15 Nov 2023
11:20 AM
15 Nov 2023
01:54 PM
I have synthetic monitors that are set to run from these different locations.
Why is it that executing the same synthetic monitor leads to very different results (visually complete, DOM interactive etc.) depending on the location/cloud?
Selected locations for synthetic monitor
E.g. results - visually complete for load actions and XHR actions (tests carried out at the same time):
15 Nov 2023 11:25 AM
If you drill down in to the waterfalls for the different locations, what differences do you see? Are there all the same resources being called? Are there certain resources that are always taking longer? Are cdns used? Where are the application servers located and are they in the Cloud also?
