29 Oct 2024
11:29 AM
30 Oct 2024
07:52 AM
Hello. When I try to record a browser clickpath in a http only webpage I get a message of Chrome with a warning and a button to go to the page, but when I try to click in the button It doesn´t do anything. Have anyone experience something similar?
29 Oct 2024 11:47 AM
This behaviour is only seen for this page from an InCognito window. Please can you disable using an Incognito Window while recording this monitor? To do this:
chrome://extensions/ into your Chrome address bar and select Enter.You will then need to refresh the Browser Window that you are recording in and then retry the recording. This behaviour is not seen when the monitor is run on private or public locations as they do not use InCognito mode.
29 Oct 2024 05:53 PM
Thanks a lot. It works. I didn't try this because I thought that the recordings run in location in incognito mode, but I was wrong. It's good to know it.
30 Oct 2024 08:37 AM
That's great news. Yes, we only use Incognito for local recording and playback so the cookies etc from your Browser don't affect it. The executions run on locations start with a clean Browser instance every time so we don't need to worry about it there.
