06 Jul 2023
09:30 AM
07 Jul 2023
07:48 AM
We are facing an error while we try to create a synthetic monitor on the customer environment, checking the log we found the below error
[browser-BeaconSenderService-thread-1910] WARN BeaconSenderService: Failed to send beacon BeaconData[beaconEndpoint: https://localhost:9999/beacon/synthetic/browser/xxxxx-xxxx-xxxx-xxx-xxxxxxx?flavor=cors&app=xxxxxxxxxxxxxxxxxxx type: MessageType{value='BeaconRequest'}, beaconId: 1], got 401 (token: *****####))
Any ideas why the AG can't authenticate with the cluster server.
thanks,
Islam
06 Jul 2023 09:37 AM
Please can you create a chat or support ticket so we can check the Synthetic tokens are not stale in you environment.
06 Jul 2023 10:34 AM
Hi @Islam_Zedan
Please note that you are trying to send a beacon to localhost. Have you verified the configuration of your AG and synthetic monitor?
Radek
06 Jul 2023 10:59 AM
This is expected in a Private ActiveGate. The beacon goes to the localhost and is redirected to the cluster. The logs just show the localhost connection
06 Jul 2023 11:03 AM
Yes, you are right!
06 Aug 2023 01:06 PM
The problem solved after opening a support ticket, to fix the token issue.
