20 Nov 2022 07:46 AM
hey,
thanks
dor
21 Nov 2022 12:01 PM
1) You can use the API to get the most recent result and store them locally to review over time.
https://www.dynatrace.com/support/help/dynatrace-api/environment-api/synthetic-v2/synthetic-monitor-...
2) I don't believe it is possible to get the visitId as this is information from outside the script. Can you just use the time and request endpoint to filter on the WAF instead
