Synthetic Monitoring
Synthetic monitoring execution logs
dorm
Frequent Guest
hey,
  1. how can i save / log more failed synthetic failures ? on the portal i get only the last failure results.
  2. where can i find what placeholder are available for me on the tests? currenlty i created a pre-script to get a timestamp and add it to the query string so i can filter the requestes on upstream WAF that doesn't log the header with the "visit id" paramter. how can i put this visit id parameter also in the URL ?
thanks
dor
HannahM
Dynatrace Guru
Dynatrace Guru
1) You can use the API to get the most recent result and store them locally to review over time.
https://www.dynatrace.com/support/help/dynatrace-api/environment-api/synthetic-v2/synthetic-monitor-...
2) I don't believe it is possible to get the visitId as this is information from outside the script. Can you just use the time and request endpoint to filter on the WAF instead
