28 Dec 2025 01:07 AM
I’m creating Browser Synthetic monitors.
After creation, the monitor name remains with the default format SYNTHETIC_TEST-XXXX, even though I explicitly change the Monitor Name field in the configuration and save the changes.
28 Dec 2025 08:28 PM
It should work.
Please try the following: Open the Browser Synthetic test --> Click View settings --> In the Monitor name field, change the name --> Save the changes.
After saving, the monitor should display the updated name correctly instead of the default SYNTHETIC_TEST-XXXX.
If it still doesn’t update:
28 Dec 2025 08:43 PM
I’ve renamed the monitor multiple times, however it still keeps the SYNTHETIC_TEST-* name.
Additionally, when I create a dashboard, both names appear
(the auto-generated SYNTHETIC_TEST-* and the custom name).
I’ve tested several options and noticed the following:
This behavior only happens with Browser synthetic monitors
For HTTP synthetic monitors, the dashboards display the correct synthetic monitor name without duplication
So far, the issue seems to be specific to Browser monitors, not HTTP monitors.
29 Dec 2025 10:47 AM
The url will always contain the monitor ID rather than the monitor name.
